Problem z ERG załaczma logi BS I statyczne
MustangGT
Pewka.pl
Silnik: 1.9TDI 110KM
Wysłany: 2010-05-30, 21:31   Problem z ERG załaczma logi BS I statyczne
Hejka mam problemik z ERG tu logi:
BS:
Sunday,30,May,2010,17:21:01
028 906 021 GH,,1.9l R4 EDC G10AG 1425,
,Group A:,'003,,,,Group B:, Not Running,,,,Group C:, Not Running
,,Engine speed,MAF (specified),MAF (actual),EGR duty cycle,,,,,,,,,,
,TIME,861-945,240-340,240-340,4-84,TIME,,,,,TIME,,,,
Marker,STAMP, /min,, mg/str, %,STAMP,,,,,STAMP,,,,
,0.01,861,EGR On,305.0,99.6,,,,,,,,,,
,0.32,861,EGR On,300.0,99.6,,,,,,,,,,
,0.64,861,EGR On,300.0,99.6,,,,,,,,,,
,0.96,861,EGR On,300.0,99.6,,,,,,,,,,
,1.28,861,EGR On,295.0,99.6,,,,,,,,,,
,1.59,861,EGR On,300.0,99.6,,,,,,,,,,
,1.95,861,EGR On,300.0,99.6,,,,,,,,,,
,2.30,861,EGR On,295.0,99.6,,,,,,,,,,
,2.66,861,EGR On,300.0,99.6,,,,,,,,,,
,3.02,861,EGR On,295.0,99.6,,,,,,,,,,
,3.38,861,EGR On,295.0,99.6,,,,,,,,,,
,3.73,861,EGR On,300.0,99.6,,,,,,,,,,
,4.10,861,EGR Off,300.0,99.6,,,,,,,,,,
,4.42,861,EGR Off,495.0,0.0,,,,,,,,,,
,4.76,861,EGR Off,500.0,0.0,,,,,,,,,,
,5.08,861,EGR Off,510.0,0.0,,,,,,,,,,
,5.41,861,EGR Off,500.0,0.0,,,,,,,,,,
,5.74,861,EGR Off,505.0,0.0,,,,,,,,,,
,6.07,861,EGR Off,510.0,0.0,,,,,,,,,,
,6.39,861,EGR Off,510.0,0.0,,,,,,,,,,
,6.72,861,EGR Off,510.0,0.0,,,,,,,,,,
,7.05,861,EGR Off,510.0,0.0,,,,,,,,,,
,7.38,861,EGR Off,515.0,0.0,,,,,,,,,,
,7.70,861,EGR Off,505.0,0.0,,,,,,,,,,
,8.03,861,EGR Off,515.0,0.0,,,,,,,,,,
,8.34,861,EGR Off,520.0,0.0,,,,,,,,,,
,8.65,861,EGR Off,505.0,0.0,,,,,,,,,,
,8.97,861,EGR Off,505.0,0.0,,,,,,,,,,
,9.31,861,EGR Off,510.0,0.0,,,,,,,,,,
,9.65,861,EGR Off,505.0,0.0,,,,,,,,,,
,10.00,861,EGR Off,515.0,0.0,,,,,,,,,,
,10.35,861,EGR Off,510.0,0.0,,,,,,,,,,
,10.71,861,EGR Off,510.0,0.0,,,,,,,,,,
,11.06,861,EGR Off,510.0,0.0,,,,,,,,,,
,11.42,861,EGR Off,515.0,0.0,,,,,,,,,,
,11.74,861,EGR Off,505.0,0.0,,,,,,,,,,
,12.07,861,EGR Off,515.0,0.0,,,,,,,,,,
,12.40,861,EGR Off,510.0,0.0,,,,,,,,,,
,12.72,861,EGR Off,510.0,0.0,,,,,,,,,,
,13.05,861,EGR Off,520.0,0.0,,,,,,,,,,
,13.38,861,EGR Off,515.0,0.0,,,,,,,,,,
,13.71,861,EGR Off,510.0,0.0,,,,,,,,,,
statyczne:
Marker,STAMP, /min, mg/str, mg/str, %,STAMP,,,,,STAMP,,,,
,0.29,861,290.0,510.0,59.8,,,,,,,,,,
,0.61,861,290.0,515.0,59.8,,,,,,,,,,
,0.95,861,290.0,510.0,59.8,,,,,,,,,,
,1.29,861,290.0,510.0,59.8,,,,,,,,,,
,1.64,861,290.0,505.0,59.8,,,,,,,,,,
,2.00,861,290.0,515.0,59.8,,,,,,,,,,
,2.35,861,290.0,510.0,59.8,,,,,,,,,,
,2.68,861,290.0,510.0,4.8,,,,,,,,,,
,3.00,861,290.0,520.0,4.8,,,,,,,,,,
,3.33,861,290.0,515.0,4.8,,,,,,,,,,
,3.66,861,290.0,510.0,4.8,,,,,,,,,,
,3.99,861,290.0,515.0,4.8,,,,,,,,,,
,4.32,861,290.0,520.0,4.8,,,,,,,,,,
,4.64,861,290.0,515.0,4.8,,,,,,,,,,
,4.97,861,290.0,515.0,4.8,,,,,,,,,,
,5.30,861,290.0,515.0,4.8,,,,,,,,,,
,5.62,861,290.0,510.0,4.8,,,,,,,,,,
,5.94,861,290.0,515.0,4.8,,,,,,,,,,
,6.26,861,290.0,505.0,4.8,,,,,,,,,,
,6.58,861,290.0,510.0,4.8,,,,,,,,,,
,6.91,861,290.0,515.0,4.8,,,,,,,,,,
,7.23,861,290.0,510.0,4.8,,,,,,,,,,
,7.56,861,290.0,510.0,4.8,,,,,,,,,,
,7.92,861,290.0,510.0,4.8,,,,,,,,,,
,8.27,861,290.0,515.0,4.8,,,,,,,,,,
,8.63,861,290.0,515.0,4.8,,,,,,,,,,
,8.99,861,290.0,505.0,4.8,,,,,,,,,,
,9.34,861,290.0,515.0,4.8,,,,,,,,,,
,9.66,861,290.0,515.0,4.8,,,,,,,,,,
,9.99,861,290.0,515.0,4.8,,,,,,,,,,
,10.32,861,290.0,510.0,4.8,,,,,,,,,,
,10.65,861,290.0,515.0,4.8,,,,,,,,,,
,10.97,861,290.0,510.0,4.8,,,,,,,,,,
,11.30,861,290.0,510.0,4.8,,,,,,,,,,
,11.63,861,290.0,520.0,4.8,,,,,,,,,,
Na sek. przed zalogowaniem statycznych dodałem gazu.
Moje pytanie brzmi dlaczego na wolnych obrotach biegu jałowym nie otwiera mi się ERG?
Czekam na odp. dzieki pozdro :)
Ostatnio zmieniony przez MustangGT 2010-05-30, 21:39, w całości zmieniany 1 raz
Wysłany: 2010-05-30, 21:42
na biegu jałowym EGR powinien być zamknięty ;)
Zaślep EGRa blaszką i po problemie ;) nawet pare koni przybędzie :D
MustangGT
Pewka.pl
Wysłany: 2010-05-30, 21:55
vezet22 napisał/a:
Dzieki za odp. :)
Ale uwarzam że na biegu jałowym ERG powinien być otwarty dzieki czemu pobór powietrza zmniejsza na przepływomierzu do 275 do 300 a przy zamknietym ERG na na jałowym biegu [pwietrze rośnie od 480 do 580.
Chcem zrobić ekologiczny samochodzik ;) czekam dalej :)
Ostatnio zmieniony przez MustangGT 2010-05-30, 21:56, w całości zmieniany 2 razy
Wysłany: 2010-05-30, 22:48
MustangGT napisał/a:
szkoda czarnej mocy :diabeł:
